Zabbix 2.0 to 2.2.0, how to get updated templates ?
  • hgomez
    • Jul 2012
    • 17
    I updated my Zabbix 2.0.9 server to 2.2.0, ESXi support was a big bonus and expected.
    I'm using Zabbix Server from openSuse.
    I was thinking it would came during SQL (MySQL) automatic upgrade process but it didn't seems.
    I tried to import 3 VSphere xml files but errors also ;(
    I notice 2.2.0 templates are using for example {HOST.NAME} whereas it was {HOSTNAME} in 2.0
    What's correct process to get Templates updated ?
  • tchjts1
    • May 2008
    • 1605
    Join the friendly and open Zabbix community on our forums and social media platforms.
    Be sure to read the notes... particularly as relating to importing the VMWare templates:
    Note: Template App Zabbix Server has been hacked to import successfully - direct import will fail in some cases. See ZBX-7338 for more detail
    Note: FreeBSD and OpenBSD templates are broken in the 2.2.0 release and thus are not included at this time. See ZBX-7339 for more detail
    Note: Template Virt VMware should be imported after the other VMware templates, otherwise it will fail with mysterious message. See ZBX-7340 for more detail
