I recently added an item and trigger to my setup. This calls a script on the agent side and it takes on average 8.5 seconds to execute. Now I have already updated the timeout setting on both the agent (client side) and server side to 15 seconds. So I know that isn't the issue.
The main problem is that when I make the call using zabbix_get, I get a return just fine, but after adding the item to the server side, my trigger gets set to not supported.
The trigger is setup as {host:event.checkToMake.last(0)}=1
I have setup other events like this, and they have all worked fine. Can someone point me to where I have gone wrong? Thanks,
