Delayed trigger
  • rsokoll
    • Jun 2018
    • 11
    Delayed trigger
    I want to get notified only if a value stays for at least 10 Minutes over a defined level:
    {router.remoteoffice.example.com:net.if.out[tun0].min(600)}>0.1M or {router.remoteoffice.example.com:n[URL="http://et.if.in/"]et.if.in[/URL][tun0].min(600)}>0.1M
    But the trigger fires immediately.
    By reading https://www.zabbix.com/documentation...gers/functions I would expect that the trigger fires after 10 Minutes?
    What am I missing?
    (Zabbix 3.4)
  • kernbug
    • Feb 2013
    • 329
    What am I missing?
    (Zabbix 3.4)
    Hello
    Please, show latest data for:
    router.remoteoffice.example.com:net.if.in[tun0]
    • Linwood
      • Dec 2013
      • 398
      One problem could be a startup on. If you have no data for 10 minutes (newly discovered item, new host), then the first data item meets that criteria, it will fire. You could do a count test to make sure there's enough data for the min to be meaningful.
      • kloczek
        • Jun 2006
        • 1771
        • rsokoll
          • Jun 2018
          • 11
          Originally posted by kernbug
          Hello
          router:~ # zabbix-agentd -t net.if.in[tun0]
          net.if.in[tun0]                               [u|124455731947]
          router:~ #
          router:~ # zabbix-agentd -t net.if.out[tun0]
          net.if.out[tun0]                              [u|34026575514]
          router:~ #
          So I do have data.
          Also I see data in Monitoring -> latest data.
          • rsokoll
            • Jun 2018
            • 11
            A note: The agentd is 2.2.21, while the server is 3.4 - but that should not cause problems, I hope?
            • kloczek
              • Jun 2006
              • 1771
              Dosn't matter.
              In zabbix stack triggers are always and only evaluated on the server.
              • rsokoll
                • Jun 2018
                • 11
                I'm an idiot.
                There is no problem and there never was. I'm testing the wrong way.
                I wrongly assumed that after storing the trigger, it will evaluate the next 600 seconds. But it evaluates the past 600 seconds, and the values are above 0.1M, so the trigger fires immediately.
                Sorry for the noise.
