zabbix store data in Elasticsearch with partition index name
  • Rossonero224
    • Jan 2013
    I'm using zabbix 3.4 with elasticsearch as backend. Everything works great and the performance is very good.
    But after some times, I see that the index size in elasticsearch increases a lot. I read that housekeeper does not work with data in Elasticsearch.
    Elasticsearch has a great feature that allow the index can be partition by day. For ex : uint index, can be partitioned to : unit-[YYYY-MM-DD] and old data can be backup and purged easily from ES.
    So, I wonder if zabbix can support to use partition index name in elasticsearch?
  • kernbug
    • Feb 2013
    • 329
    Hi
    According to https://www.zabbix.com/rn/rn4.0.0alpha7 ​​​you are welcome to test this feature
    ZBXNEXT-4320 added ability to store history data in date based indices of elasticsearch
    • Rossonero224
      • Jan 2013
      Originally posted by kernbug
      Hi
      Thanks, I will try it
      • Rossonero224
        • Jan 2013
        just updated from 3.4 to 4.0.9 alpha and followed this guide : https://www.zabbix.com/documentation...c_search_setup to add support for index partition by day in elasticsearch.
        Everything seems fine
