Zabbix shows input/output traffic from router (snmp) less than actual.
  • zabbixfk
    • Jun 2013
    • 256
    Hello All,
    I have configured router to send snmp data to zabbix, where i see that input and output traffic readings are shown less when compared to router readings.
    If i do snmpwalk, i get below data, (something like 350kbps )
    IF-MIB::ifInOctets.22 = Counter32: 351772510
    Where zabbix shows 3.5kbps. ( suppose to show 350 kbps )
    Settings on zabbix is as follows,
    Key : ifOutOctets.11
    OID : .1.3.6.1.2.1.2.2.1.16.11
    Type : Numeric ( unsigned )
    Datatype : Decimal
    Units : bps
    custom multiplier : 8
    Store value : Delta ( speed per second).
    Am i missing something here, does unit or custom multiplier needs to be changed? Any pointers are greatly helpful.
    Thanks.
  • aib
    • Jan 2014
    • 1615
    Are you sure, that two different interfaces has to have the same traffic?
    In snmpwalk you checked Incoming traffic on interface 22:
    IF-MIB::[B]ifInOctets.22[/B] = Counter32: 351772510
    But in Zabbix you check Outgoing traffic on interface 11 :
    Key : [B]ifOutOctets.11[/B]
    It confuses me.
    Could you check the result of snmpwalk for ifOutOctets.11 and compare it with Zabbix item?
    Sincerely yours,
    Aleksey
    • zabbixfk
      • Jun 2013
      • 256
      Yes, i am also monitoring interface 22. ( about 2-3 interfaces are being monitored) - and for all i am getting traffic less than what is shown on router end.
      • aib
        • Jan 2014
        • 1615
        Is it possible that you have so heavy traffic that your counter overflow between updates?
        For some heavy loaded interfaces is better to use Counter64 (if your router can provide it). Especially for 1Gbit/10Gbit interfaces.
        For additional information check CISCO: SNMP Counters: Frequently Asked Questions
        Sincerely yours,
        Aleksey
        • zabbixfk
          • Jun 2013
          • 256
          Thanks for the reply.
          The router has only 512kbps connection, and i think that's not a heavy load. SNMPWalk shows Counter32 with the number, zabbix database has the same number. That means router is sending it properly, and zabbix database ( items table) has correct data. Only problem is showing it in the UI.
          Looks like, something to do with custom multplier 8 or bps as a unit.
          Thanks.
          • rekeds
            • Feb 2014
            • 21
            octet is 8 bits, if you want bps, use multiplier 8.
