is it possible to pass a array to external script? Let me describe a situation and there is maybe a better solution that I am trying.
I have several servers in a cluster and just one is in active state hence should be monitored.
My initial idea was to create external script which is passed an array of possible nodes in cluster and script will find an active one and get appropriate parameters.
The number of nodes in cluster is variable - can happen that there is just one active.
I wanted to avoid a situation having the same template applied to every host and active parameter would just say that this one is worth looking as non active doesn't provide correct info as they are not synchronized.
Any hints appreciated
Thx
Thx
