aws sns emails to zabbix
  • dragan979
    • Apr 2018
    • 49
    i configured asw config with sns emails,now i need some way to redirected all those emails to zabbix.
    is it possible somehow to redirect all emails from office365 mailbox to zabbix,to create alerts from it ?.
    i searched google and it seems that it's possible with SMS only ?
  • kernbug
    • Feb 2013
    • 329
    Hi
    If you need to receive mail from Amazon to Zabbix, you need to configure console mail client on the Zabbix Server or write a script that will parse the letters in the mailbox and write the data to the Zabbix (zabbix_sender).
    • dragan979
      • Apr 2018
      • 49
      Originally posted by kernbug
      Hi
      Thanks kernbug, can you please give me some steps or some links ?
      Thanks !
      • kernbug
        • Feb 2013
        • 329
        Thanks !
        What programming language you are familiar with? General steps: fetch mail (console client or script (Go,Python/Perl/Bash)), do some logic to check, send result to the Zabbix with zabbix_sender!
        • dragan979
          • Apr 2018
          • 49
          this post must be deleted
          • jan.garaj
            • Jan 2010
            • 506
            Why you don't subscribe AWS SQS queue to your AWS SNS topic and then process queue. Or create&subscribe Lambda function to your AWS SNS topic and function will parse data and it will push them into your Zabbix.
            This one seems to be better AWS solution, than using SMTP/emails.
            • dragan979
              • Apr 2018
              • 49
              uh,thanks again,didn't know it's possible, can you give me some starting point for lambda function ?,no idea how to start
              • jan.garaj
                • Jan 2010
                • 506
                In this tutorial, you use a Lambda Event Function in one AWS account to subscribe to an Amazon Simple Notification Service (Amazon SNS) topic in a separate AWS account. When you publish messages to your Amazon SNS topic, your Lambda Event Function reads the contents of the message and outputs it to Amazon CloudWatch Logs. To complete this tutorial, you use the AWS Command Line Interface (AWS CLI).
