FUJITSU ETERNUS DX100 s3 monitoring
  • mykolaq
    • May 2015
    • 69
    Did somebody monitor this storage system by zabbix?
    I am trying to make template with snmp and have some problems with this one:
    1) some data by snmp from this server is in hex. For example [
    root@zabbix]# snmpget  -v 2c -c public 192.168.1.1 FJDARY-E150::fjdaryOluInfoTable.3
    FJDARY-E150::fjdaryOluInfoTable.3 = Hex-STRING: 06 00 00 A0 01 00 FF FF 00 FF 00 00 00 00 00 00
    00 00 00 80 00 00 00 00 08 00 FF FF FF FF FF FF
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00
    2) I have tried to get data with parameter -Oa. No normal result. For example:
    [root@zabbix]# snmpget  -Oa -v 2c -c public 192.168.1.1 FJDARY-E150::fjdaryOluInfoTable.3
    (...(Y-E150::fjdaryOluInfoTable.3 = STRING: "................................................................Name1.......................`...
    (...(..................................Name2............................`...
    3) I didnt find disk serial numbers, slot numbers with enclosure nmber, etc.
    Maybe somebody can help me?
  • kernbug
    • Feb 2013
    • 329
    Please, show output from:
    snmptranslate FJDARY-E150::fjdaryOluInfoTable.3 -Td
    • mykolaq
      • May 2015
      • 69
      [root@zabbix myscripts]# snmptranslate FJDARY-E150::fjdaryOluInfoTable.3 -Td
      fjdaryOluInfoTable OBJECT-TYPE
        -- FROM       FJDARY-E150
        SYNTAX        OCTET STRING (0..256)
        MAX-ACCESS    read-only
        STATUS        current
        DESCRIPTION   "The value of this object indicates the OLU information.
               This information is a little endian.
                        byte 0       byte 1       byte 2       byte 3
                0x00|OLU info#index*2 (96 bytes)                        |
                0x60|OLU info#index*2+1 (96 bytes)                      |
               OLU info#
                0x00|OLUN                     |Status                   |
                0x04|SLU Count   |Reserved    |Pool No                  |
                0x08|Reserved                                           |
                0x14|                                                   |
                0x18|SLUN 0x00                |SLUN 0x01                |
                0x34|SLUN 0x0E                |SLUN 0x0F                |
                0x38|Reserved                                           |
                0x5c|                                                   |
      ::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) fujitsu(211) product(1) storage(21) nsp(1) fjdarye150(150) fjdaryLconfig(3) fjdaryOlu(2) fjdaryOluTable(2) fjdaryOluEntry(1) fjdaryOluInfoTable(2) 3 }
      • kernbug
        • Feb 2013
        • 329
        [CODE][root@zabbix myscripts]# snmptranslate FJDARY-E150::fjdaryOluInfoTable.3 -Td
        -- FROM FJDARY-E150
        What data value type do you use for the item?
        • mykolaq
          • May 2015
          • 69
          i didnt use something from this in zabbix now, cause i dont understand why it is showing me more than one value for one item (in example - volume name)
          • kernbug
            • Feb 2013
            • 329
            I'think you need to check MIB files.
