problem with zabbix installation
  • mustafa nassir
    • Jun 2018
    hi there i install zabbix but i have problem with , when i start zabbix with systemctl start zabbix-server i have this :
    27 10:26:20 localhost.localdomain systemd[1]: Failed to start Zabbix Server.
    -- Subject: Unit zabbix-server.service has failed
    -- Defined-By: systemd
    -- Support: http://lists.freedesktop.org/mailman.../systemd-devel
    -- Unit zabbix-server.service has failed.
    -- The result is failed.
    يون 27 10:26:20 localhost.localdomain systemd[1]: Unit zabbix-server.service entered failed state.
    يون 27 10:26:20 localhost.localdomain systemd[1]: zabbix-server.service failed.
    يون 27 10:26:30 localhost.localdomain systemd[1]: zabbix-server.service holdoff time over, scheduling restart.
    يون 27 10:26:30 localhost.localdomain systemd[1]: Starting Zabbix Server...
    -- Subject: Unit zabbix-server.service has begun start-up
    -- Unit zabbix-server.service has begun starting up.
    يون 27 10:26:30 localhost.localdomain systemd[1]: PID file /run/zabbix/zabbix_server.pid not readable (yet?) after start.
    يون 27 10:26:30 localhost.localdomain systemd[1]: zabbix-server.service never wrote its PID file. Failing.
    يون 27 10:26:30 localhost.localdomain systemd[1]: Failed to start Zabbix Server.
    يون 27 10:26:30 localhost.localdomain systemd[1]: Unit zabbix-server.service entered failed state.
    يون 27 10:26:30 localhost.localdomain systemd[1]: zabbix-server.service failed.
    يون 27 10:26:40 localhost.localdomain systemd[1]: zabbix-server.service holdoff time over, scheduling restart.
    يون 27 10:26:40 localhost.localdomain systemd[1]: Starting Zabbix Server...
    يون 27 10:26:40 localhost.localdomain systemd[1]: PID file /run/zabbix/zabbix_server.pid not readable (yet?) after start.
    يون 27 10:26:40 localhost.localdomain systemd[1]: zabbix-server.service never wrote its PID file. Failing.
    يون 27 10:26:40 localhost.localdomain systemd[1]: Failed to start Zabbix Server.
    يون 27 10:26:40 localhost.localdomain systemd[1]: Unit zabbix-server.service entered failed state.
    يون 27 10:26:40 localhost.localdomain systemd[1]: zabbix-server.service failed.
    i install it with centos 7 os , mariadb ,httpd ,php
    zabbix gui work fine but the server dose not work pleas help
  • kernbug
    • Feb 2013
    • 329
    Please, show us output from this command:
    sudo sestatus -v
    • mustafa nassir
      • Jun 2018
      hi , my dear this is output
      SELinux status: enabled
      SELinuxfs mount: /sys/fs/selinux
      SELinux root directory: /etc/selinux
      Loaded policy name: targeted
      Current mode: enforcing
      Mode from config file: enforcing
      Policy MLS status: enabled
      Policy deny_unknown status: allowed
      Max kernel policy version: 28
      Process contexts:
      Current context: unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023
      Init context: system_u:system_r:init_t:s0
      /usr/sbin/sshd system_u:system_r:sshd_t:s0-s0:c0.c1023
      File contexts:
      Controlling terminal: unconfined_ubject_r:user_devpts_t:s0
      /etc/passwd system_ubject_rasswd_file_t:s0
      /etc/shadow system_ubject_r:shadow_t:s0
      /bin/bash system_ubject_r:shell_exec_t:s0
      /bin/login system_ubject_r:login_exec_t:s0
      /bin/sh system_ubject_r:bin_t:s0 -> system_ubject_r:shell_exec_t:s0
      /sbin/agetty system_ubject_r:getty_exec_t:s0
      /sbin/init system_ubject_r:bin_t:s0 -> system_ubject_r:init_exec_t:s0
      /usr/sbin/sshd system_ubject_r:sshd_exec_t:s0
      [root@localhost ~]#
      • kernbug
        • Feb 2013
        • 329
        Try this, restart server process and check up the Zabbix log (/var/log/zabbix/zabbix_server.log):
        sudo setenforce 0;
        • mustafa nassir
          • Jun 2018
          i do it its same this output of log file
          1517:20180626:085857.836 Starting Zabbix Server. Zabbix 3.4.11 (revision 82160).
          1517:20180626:085857.837 ****** Enabled features ******
          1517:20180626:085857.837 SNMP monitoring: YES
          1517:20180626:085857.837 IPMI monitoring: YES
          1517:20180626:085857.837 Web monitoring: YES
          1517:20180626:085857.837 VMware monitoring: YES
          1517:20180626:085857.837 SMTP authentication: YES
          1517:20180626:085857.837 Jabber notifications: YES
          1517:20180626:085857.837 Ez Texting notifications: YES
          1517:20180626:085857.837 ODBC: YES
          1517:20180626:085857.837 SSH2 support: YES
          1517:20180626:085857.837 IPv6 support: YES
          1517:20180626:085857.837 TLS support: YES
          1517:20180626:085857.837 ******************************
          1517:20180626:085857.837 using configuration file: /etc/zabbix/zabbix_server.conf
          1517:20180626:085857.837 cannot set resource limit: [13] Permission denied
          1517:20180626:085857.837 cannot disable core dump, exiting...
          1520:20180626:085908.046 Starting Zabbix Server. Zabbix 3.4.11 (revision 82160).
          1520:20180626:085908.046 ****** Enabled features ******
          1520:20180626:085908.046 SNMP monitoring: YES
          1520:20180626:085908.046 IPMI monitoring: YES
          1520:20180626:085908.046 Web monitoring: YES
          1520:20180626:085908.046 VMware monitoring: YES
          1520:20180626:085908.046 SMTP authentication: YES
          1520:20180626:085908.046 Jabber notifications: YES
          1520:20180626:085908.046 Ez Texting notifications: YES
          1520:20180626:085908.046 ODBC: YES
          1520:20180626:085908.046 SSH2 support: YES
          1520:20180626:085908.047 IPv6 support: YES
          1520:20180626:085908.047 TLS support: YES
          1520:20180626:085908.047 ******************************
          • mustafa nassir
            • Jun 2018
            oh fine its work thank you for your help my dear but why after each rebbot for centos machine i should use
            sudo setenforce 0; and restart zabbix to work
            • kernbug
              • Feb 2013
              • 329
              Nope, edit /etc/sysconfig/selinux and set SELINUX=permissive:
              # This file controls the state of SELinux on the system.
              # SELINUX= can take one of these three values:
              #     enforcing - SELinux security policy is enforced.
              #     permissive - SELinux prints warnings instead of enforcing.
              #     disabled - No SELinux policy is loaded.
              SELINUX=permissive
              Another option is to follow setup procedure step by step with additional audit2allow utilities: https://www.zabbix.com/documentation...es/rhel_centos
