Include part of textfile in email notification
  • zswss
    • Jun 2018
    I'm monitoring a text file on windows. When the file contains the string "example" I receive an email. Setup of Item and Trigger is as follows:
    Item:
    Type= Zabbix agent (active)
    Key= vfs.file.regmatch[c:\zabbix\Test.txt,"example",,,10]
    Type= Numeric (unsigned)
    Trigger:
    {hostname:vfs.file.regmatch[c:\zabbix\test.txt,"example",,,10].last()}=1
    The textfile will look something like this:
    06/27/2018 06:00:04 this is example1.
    06/27/2018 06:00:04 this is example4
    06/27/2018 06:00:04 this is example6
    or :
    06/27/2018 06:00:00 nothing to report.
    Is it possible to include every occurence of "example" in the email zabbix sends? And if so, how?
    (Zabbix 3.4.7)
  • kernbug
    • Feb 2013
    • 329
    (Zabbix 3.4.7)
    You can perform an action if trigger fired up: https://www.zabbix.com/documentation...remote_command
    Trigger->Remote Action (get data from log file)-> Send data via e-mail
    or
    Trigger -> Trigger Action (remotely get data from log)-> Send an alert via email with the attachemnent (getting data from the host may be very slow, performance impact on the alerter and escalator)
    • zswss
      • Jun 2018
      or
      I understand the principle of remote actions; I have them set up to start services if a trigger is fired. (this to indicate everything is set up correctly for use of remote commands)
      I'm assuming I need to configure two steps in Actions-->Operations?
      One to run the command, one to send the message? How do I include the results of the command to get sent with the alert?
      Could you please show me an example of how to set this up?
