SMS script doesn't send SMSes on alert
  • alfredballe
    • Jun 2018
    I've got a script for sending SMSes with Nexmo.com, called sms.sh.
    This is my zabbix_server.conf parameter:
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    This is my /usr/lib/zabbix/alertscripts/sms.sh:
    #!/usr/bin/env bash
    /usr/bin/curl -X POST https://rest.nexmo.com/sms/json \
    -d api_key=$1 \
    -d api_secret=$2 \
    -d to=$3 \
    -d from=$4 \
    --data-urlencode "text=$5"
    This script works when manually calling it.
    I've done ​​​​​​​chown root:zabbix sms.sh and ​​​​​​​chmod 750 sms.sh on sms.sh.
    In Zabbix Dashboard I've updated the SMS Media Type to type "Script" with script name "​​​​​​​/usr/lib/zabbix/alertscripts/sms.sh" (also tried simply sms.sh), and have the 5 parameters.
    Also added the Media Type to my user.
    But... No SMSes are send on alerts.
    I've run:
    grep -r -i "sms" *
    in /var/log/zabbix, but there aren't found anything.
    ​​​​​​​What to do?
  • kernbug
    • Feb 2013
    • 329
    What to do?
    Is this script executed from the zabbix account?
    ### example
    ​​​​​​​sudo -H -u zabbix bash -c 'echo "I am $USER, with uid $UID"'
    • alfredballe
      • Jun 2018
      It is executable from the zabbix user. Just tested with
      sudo -H -u zabbix ./sms.sh
      That works.
