Can a host have both passive and active agents?
  • xtonymarsx
    • Jun 2018
    I just started using zabbix a couple of weeks ago. So I'm quite the novice. I tried to search the boards, but didn't see any similar threads.
    Due to strict bandwidth and data restrictions, I have many of my hosts set up with passive agents, but I also need to do some log monitoring which can only be achieved with active agents (at least that's my understanding). Can a single host use both active and passive agents?
    I verified that the proxy is listening on port 10051. On the agent config, I have left the default port as 10050 (for the passive monitoring), but also exclusively set the ServerActive=<proxyIP>:10051. In the agent log, I see that agent is now starting an active check, but I don't see any connections for 10051 in my netstat.
  • kernbug
    • Feb 2013
    • 329
    Hi
    You're welcome!
    One single agent can perform active and passive checks! So, yes, but you don't need to install it twice)
    Take a look here https://www.zabbix.com/documentation...concepts/agent
    Correct, 'Server=' for passive checks, 'ServerActive=' for the active checks.
    Hm, I think you forget to set 'Monitored by proxy' in the web frontend (Administration-Hosts-Host settings-Monitored by proxy). Please, check.
    • xtonymarsx
      • Jun 2018
      Thanks for the reply. Apparently I had it set up correctly. I had to clear the cache on the proxy for some reason before it recognized the new items/triggers that I'd created for the active agents.
      • kernbug
        • Feb 2013
        • 329
        You can reload configuration cache by runtime control to apply changes immediately:
         sudo zabbix_proxy -R config_cache_reload
