Zabbix macros doesn't work working in maps
  • amlife
    • Sep 2013
    • 15
    Hello everyone
    I have been trying for hours to display bandwidth network speed, something I used to do using older versions, I'm currently using 2.2 and I wonder why this doesn't work.
    PS: I have working graphs for eth0 and data gets updated correctly.
    Incoming traffic: {{HOSTNAME}:net.if.in[eth0].last(0)}
    Outgoing traffic: {{HOSTNAME}:net.if.out[eth0].last(0)}
    Please find the attached image.
  • amlife
    • Sep 2013
    • 15
    anyone can help?
    • aib
      • Jan 2014
      • 1615
      I try to do what do you want and I also cannot get it to show the correct numbers instead of NAME_OF_MACROS.
      sorry
      Sincerely yours,
      Aleksey
      • amlife
        • Sep 2013
        • 15
        I hope its not a bug with version 2.2
        • aib
          • Jan 2014
          • 1615
          It works only when I give the name of real host from any side of link.
          like
          {{Server1:ifInOctets[eth0].avg(300)}
          Looks like when I use macro name, Zabbix cannot guess which side of link has to be used as HOST.NAME.
          Yes, I try to use HOST.NAME1 and HOST.IP1 - no luck.
          Sincerely yours,
          Aleksey
          • amlife
            • Sep 2013
            • 15
            Thanks, I got mine working after using hostname as you mentioned
