The solution to this is evading me.
I have 2 identical server. server01 server 02
The both have identical item checks.
log["/var/log/mirth/primary/mirth.log",TransformerException,,,]
So I get this on server01
24969:20140204:105424.402 In process_active_checks('10.2.0.11',10051)
24969:20140204:105424.402 In process_log() filename:'/var/log/mirth/primary/mirth.log' lastlogsize:411133
24969:20140204:105424.403 End of process_active_checks()
uid=498(zabbix) gid=499(zabbix) groups=499(zabbix) context=unconfined_u:unconfin
drwxr-xr-x. 17 root root 4096 May 10 2013 var
drwxr-xr-x. 7 root root 4096 Feb 2 03:13 log
drwxr-xr-x. 3 mirth mirth 4096 May 28 2013 mirth
-rw-rw-r--. 1 mirth mirth 428967 Feb 4 11:14 mirth.log
On server02, I get this.
26044:20140203:101700.523 In process_log() filename:'/var/log/mirth/primary/mirth.log' lastlogsize:0
26044:20140203:101700.523 cannot open '/var/log/mirth/primary/mirth.log': [13] Permission denied
26044:20140203:101700.523 active check "log["/var/log/mirth/primary/mirth.log",TransformerException,,,]" is not supported
26044:20140203:101700.524 In process_value() key:'mirth-02:log["/var/log/mirth/primary/mirth.log",TransformerException,,,]' value:'ZBX_NOTSUPPORTED'
Permissions, contents of zabbix_agentd.conf, are all identical.
