Monitoring CPU usage of Apache
  • carlos.pereira
    • Jun 2018
    Hello!
    I'm a beginner to Zabbix. Also, I'm learning English, so... I can make mistakes sometimes.
    I was able to configure Zabbix for monitoring the Apache's status (wheter it's online or not). But I need now that the Zabbix monitors the CPU usage of only the Apache's process (or service) of a Linux server.
    Is there some way of do it?
  • kernbug
    • Feb 2013
    • 329
    Originally posted by carlos.pereira
    Hello!
    Yes, you can use this parameters:
    • proc.num - can monitor the number of processes, based on process name, user, parameters etc
    • proc.mem - can monitor process memory usage (single process or a group of them)
    • proc.cpu.util - can monitor process CPU utilisation (single process or a group of them)
    Full information about parameters and options: https://www.zabbix.com/documentation...s/zabbix_agent
    • carlos.pereira
      • Jun 2018
      For I to define a default parameter, is it enough that I put like this: "proc.cpu.util[apache,<user>,<type>,<cmdline>,<mode>,<zone>]" or must I put the others parameters empty?
      • LenR
        • Sep 2009
        • 1011
        proc.cpu.util][apache] should be good, I think you must remove the ones in <..> or you will get errors, but you can omit trailing commas. proc.cpu.util[,root] would get CPU for all root processes. (Not useful, just an example of the place holder comma)
        • carlos.pereira
          • Jun 2018
          I put like this: "proc.cpu.util[apache]" but it give me the message: "Unsupported item key" and it don't work. What can it be?
          • kernbug
            • Feb 2013
            • 329
            Run this command on the server with apache:
            sudo -H -u zabbix -s /path/to/your/bash -c 'ps aux|grep -i apache'
            • carlos.pereira
              • Jun 2018
              I did it and this command showed me all the services with apache that are running.
              • kernbug
                • Feb 2013
                • 329
                Please, show me the exact output from this command.
                • carlos.pereira
                  • Jun 2018
                  Ok. The image is attached.
                  • Atsushi
                    Atsushi commented
                    Please try to use "proc.cpu.util[httpd]".
                  • carlos.pereira
                    carlos.pereira commented
                    When I put "proc.cpu.util[httpd]" the zabbix show me this message: "Unsupported item key".
