Database Query related concern
  • vnoc
    • Sep 2017
    • 115
    Hi All,
    I was trying to implement database query related alerts and followed the below link but getting an error while executing the query (isql test is what I executed). Destination Database is MySQL/mariadb
    https://www.zabbix.com/documentation...es/odbc_checks
    Kindly help me in fixing this please.
  • kernbug
    • Feb 2013
    • 329
    Originally posted by vnoc
    Hi All,
    What steps did you follow from this manual and managed to do? Please, show odbc configuration files (odbc.ini and odbcinst.init)?
    • vnoc
      • Sep 2017
      • 115
      Thanks for your response . At present I have connected to the test database server but here my exact requirement is below and for that I used the link which I mentioned in the above . I am now stuck at
      15.5 Compiling Zabbix with ODBC support
      To enable ODBC support, Zabbix should be compiled with one of following flags:
      --with-iodbc[=ARG] use odbc driver against iODBC package [default=no], --with-unixodbc[=ARG] use odbc driver against unixODBC package
      But I have installed my Zabbix through rpm and how to recompile it and after that how to fulfill the below requirement
      "I want to execute a database query and monitor its output by configuring thresholds through Zabbix."
      • kernbug
        • Feb 2013
        • 329
        RPM's are already build with ODBC support. You need to create a .my.cnf file in the zabbix user's home directory and register login/password from your database in it, set user rights for the user zabbix. After that you can check the connectivity using the command: sudo -H -u zabbix -s /path/bash -c 'isql ...'. If this command works you can try to setup item in the Zabbix frontend.
        • vnoc
          • Sep 2017
          • 115
          And where can I find the Zabbix user path. In Zabbix there is 2 options
          Key
          Name
          db.odbc.select[<unique short description>,<dsn>]
          Return first column of the first row of the SQL query result.
          db.odbc.discovery[<unique short description>,<dsn>]
          Transform SQL query result into a JSON object for low-level discovery.
          1 is giving only one column output
          another giving me error as below
          Cannot convert column #2 name to macro
          Actual query I have written is
          select column,count(*) from xxx
          the database connectivity is written in vi /etc/odbc.ini .
          Kindly help me in fulfilling my requirement
          • vnoc
            • Sep 2017
            • 115
            Can anyone let me know if above requirement is possible in Zabbix or is there any possible way to fulfill the above requirement
            • kernbug
              • Feb 2013
              • 329
              Simple way(without .my.cnf setup):
              4 Set up Items with type Database Monitor
