Last 20 Issues not resetting when item not supported
  • tiller
    • Dec 2011
    Hello, in the zabbix_agentd.conf file I have disabled a user parameter where that parameter has generated an issue in the last 20 issues section of the dashboard. I would like the issue to go away, but a question mark appears next to the issue. I have gone into configuration-template-item and cleared history with no success. The only way I have found to clear this out is to unlink the host with the template. I am on zabbix server version 2.2.1 agent version 2.2.1.
    Thank you
    Tiller
