Flipping a received value from 0 to 1 and vice-versa
  • TheHorseman1976
    • Jul 2018
    Greetings,
    I am monitoring several routers via SNMP and I need to send the result of the [icmpping] key to a third party application, only I need to "flip" the response around so that if [ICMPPING] returns a '1' I want Zabbix to store a '0' and vice-versa.
    Yes I know this sounds weird, but the application in question has certain things that work using an "ascending logic" so I would need my offline value to be '1' instead of a '0'.
    Could I achieve this through Calculated Items or Dependent Items? Like putting the normal result into an Item and them creating either based on that item?
    I tried to make sense of the documentation and honestly couldn't make any progress.
    Any help would be greatly appreciated.
  • kernbug
    • Feb 2013
    • 329
    Originally posted by TheHorseman1976
    Greetings,
    You can use external check or custom script (user.parameter in the Zabbix Agent):
    Also don't forget to invert the trigger expression: 0 - ok, 1 - problem.
