Network maps are not uploaded
  • sanhces7
    • Dec 2015
    • 17
    Hello colleagues! Please, i need help!
    I actively use network maps, and the problem always appears - when loading a network map it may not load completely, or leave a white box. Sometimes icons of devices without links appear. Sometimes the first time it loads normally. It is treated by repeated pressing F5 with reboot of the map - sooner or later loading takes place. The problem was noticed on Zabbix 3.4.6, updated to 3.4.11 - the problem remained. MySQL database. Tell me where to dig, please.
  • kernbug
    • Feb 2013
    • 329
    You should start by diagnosing the performance of the server on which the Zabbix database is running (slow queries, storage performance, etc.)
    • sanhces7
      • Dec 2015
      • 17
      Thanks for the answer!
      Let's take the following steps:
      - slow requests are present, start with the phrase:
      "slow query: 1.092355 sec, "insert into history_uint (itemid,clock,ns,value) values (......."
      - RAM is 8 Gb, used 70%:
      info from htop - Mem[|||||||||||||||||||||||||||||||||||||||||||||||||| ||||||||||||||||||||||||###********************5.3 0G/7.79G]
      - a server based on a virtual machine (virtualization environment is Hyper-V). There are no claims to storage performance.
      -mysqltuner gives the following recommendations:
      -------- Performance Metrics -------------------------------------------------
      [--] Up for: 2d 1h 45m 0s (15M q [87.970 qps], 379K conn, TX: 35B, RX: 3B)
      [--] Reads / Writes: 37% / 63%
      [--] Binary logging is disabled
      [--] Total buffers: 4.5G global + 24.7M per thread (214 max threads)
      [!!] Maximum reached memory usage: 9.7G (124.40% of installed RAM)
      [!!] Maximum possible memory usage: 9.7G (124.09% of installed RAM)
      [OK] Slow queries: 0% (24/15M)
      [!!] Highest connection usage: 100% (215/214)
      [OK] Aborted connections: 0.17% (632/379382)
      [OK] Query cache efficiency: 61.3% (4M cached / 6M selects)
      [!!] Query cache prunes per day: 123191
      [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 13M sorts)
      [OK] Temporary tables created on disk: 3% (37K on disk / 1M total)
      [OK] Thread cache hit rate: 99% (216 created / 379K connections)
      [!!] Table cache hit rate: 0% (400 open / 445K opened)
      [OK] Open file limit used: 0% (1/1K)
      [OK] Table locks acquired immediately: 100% (38K immediate / 38K locks)
      -------- MyISAM Metrics -----------------------------------------------------
      [!!] Key buffer used: 18.2% (195M used / 1B cache)
      [OK] Key buffer size / total MyISAM indexes: 1.0G/43.0K
      [!!] Read Key buffer hit rate: 50.0% (6 cached / 3 reads)
      -------- InnoDB Metrics -----------------------------------------------------
      [--] InnoDB is enabled.
      [!!] InnoDB buffer pool / data size: 3.0G/149.7G
      [OK] InnoDB buffer pool instances: 3
      [OK] InnoDB Used buffer: 98.44% (193528 used/ 196600 total)
      [OK] InnoDB Read buffer efficiency: 99.99% (3961794347 hits/ 3962245664 total)
      [!!] InnoDB Write buffer efficiency: 0.00% (0 hits/ 1 total)
      [OK] InnoDB log waits: 0.00% (0 waits / 3471413 writes)
      -------- AriaDB Metrics -----------------------------------------------------
      [--] AriaDB is disabled.
      -------- Replication Metrics -------------------------------------------------
      [--] No replication slave(s) for this server.
      [--] This is a standalone server..
      -------- Recommendations -----------------------------------------------------
      General recommendations:
      Run OPTIMIZE TABLE to defragment tables for better performance
      Restrict Host for user@% to user@SpecificDNSorIp
      Reduce your overall MySQL memory footprint for system stability
      Reduce or eliminate persistent connections to reduce connection usage
      Increasing the query_cache size over 128M may reduce performance
      Increase table_open_cache gradually to avoid file descriptor limits
      Read this before increasing table_open_cache over 64: http://bit.ly/1mi7c4C
      Beware that open_files_limit (1024) variable
      should be greater than table_open_cache ( 400)
      Variables to adjust:
      *** MySQL's maximum memory usage is dangerously high ***
      *** Add RAM before increasing MySQL buffer variables ***
      max_connections (> 214)
      wait_timeout (< 28800)
      interactive_timeout (< 28800)
      query_cache_size (> 256M) [see warning above]
      table_open_cache (> 400)
      innodb_buffer_pool_size (>= 149G) if possible.
      Zabbix version is 3.4.11.
      I apologize in advance, I'm not lazy and I want to solve my problems myself, but I do not understand which way to move in this situation.
      • kernbug
        • Feb 2013
        • 329
        More than confident that you need to partition the database (>100Gb), check connections usage (web? api? statistics?) and increase server RAM if possible.
        • sanhces7
          sanhces7 commented
          Thank you very much!
          I'm not sure that I myself will be able to carry out partisation of the existing database, but you answered my question.
          Thanks you!
