Auto add SNMP interface IP to discovered hosts
  • myRCzabbix
    • Jun 2018
    • 39
    Hello all,
    I'm doing my first install of Zabbix and have defined a host group named "Printers". I've also defined a discovery rule for hosts in 1 subnet checked via ICMP. As for the action, I've defined conditions to be Discovery Status = UP and Host IP = range of IPs scanned. Now, I can get them all working and all hosts discovered but all the hosts will not have any value in the SNMP interface field. How do I auto-assign the IP address to the SNMP interface field without having to go into each host and editing it manually?
    Any pointers appreciated.
  • myRCzabbix
    • Jun 2018
    • 39
    So I was mucking around and I think I might have accidentally discovered the solution: in the discovery rule, you need to add a SNMP check. I added it last night and this morning, all of my discovered hosts seems to have had their SNMP interface filled in with the IP address.
    • LenR
      • Sep 2009
      • 1010
      I think if you discover using SNMPVx agent instead of icmp you would get a snmp interface, but I don't use this in our environment.
      It would probably be possible to write an API script to find these hosts and add an SNMP interface if it doesn't exist.
      • kernbug
        • Feb 2013
        • 329
        Originally posted by myRCzabbix
        Hello all,
        Add to discovery rule SNMP check and apply SNMP template to the host with LLD.
        • if a host responded to agent checks only, it will be created with an agent interface only. If it would start responding to SNMP later, additional SNMP interfaces would be added.
