Simple check for imaps
  • hpz
    • Jul 2006
    does anybody know how to implement a simple check on IMAPS (port 993) or better to do a imaps_perf?
    Hans-Peter
  • raminix
    • Jun 2006
    • 37
    Hans-Peter
    Not sure on perf, but for basic connectivity, will tcp,993 not work?
    • hpz
      • Jul 2006
      thanks, yes this works, but I didn't get to work the simplecheck 'imap_perf' !?
      hanspeter
      • raminix
        • Jun 2006
        • 37
        hanspeter
        I'm not sure if imap and imap_perf do anything beyond a basic tcp connection to the port that is imap specific. You could try it and specify the port just for kicks. I suppose it would be nice to have a tcp_perf function as well.
