HP-UX 11.11, SNMP cpu-load check
  • karmukis
    • Aug 2014
    • 37
    I'm dealing with some HP-UX 11.11 servers, and I need to check some things on it, CPU, MEM, etc., but I'm having issues with the output that I obtain from the SNMP check, I have no idea what the CPU load is express on, what unit...
    This is the check:
    (.1.3.6.1.4.1.11.2.3.1.1 OID for all CPU info)
    computerSystemUserCPU (CPU used by users) .1.3.6.1.4.1.11.2.3.1.1.13
    computerSystemSysCPU (CPU used by system) .1.3.6.1.4.1.11.2.3.1.1.14
    computerSystemIdleCPU (CPU idle) .1.3.6.1.4.1.11.2.3.1.1.15 >>> THIS IS THE ONE THAT I'm really interested in:
    [root@hostanmeee ~]# snmpwalk -v2c -c public xxx.xxx.xx.xxx .1.3.6.1.4.1.11.2.3.1.1
    SNMPv2-SMI::enterprises.11.2.3.1.1.1.0 = Timeticks: (3127521100) 361 days, 23:33:31.00
    SNMPv2-SMI::enterprises.11.2.3.1.1.2.0 = Gauge32: 0
    SNMPv2-SMI::enterprises.11.2.3.1.1.3.0 = Gauge32: 3
    SNMPv2-SMI::enterprises.11.2.3.1.1.4.0 = Gauge32: 4
    SNMPv2-SMI::enterprises.11.2.3.1.1.5.0 = Gauge32: 4
    SNMPv2-SMI::enterprises.11.2.3.1.1.6.0 = INTEGER: 8496
    SNMPv2-SMI::enterprises.11.2.3.1.1.7.0 = Gauge32: 12734836
    SNMPv2-SMI::enterprises.11.2.3.1.1.8.0 = INTEGER: 33520144
    SNMPv2-SMI::enterprises.11.2.3.1.1.9.0 = Gauge32: 0
    SNMPv2-SMI::enterprises.11.2.3.1.1.10.0 = INTEGER: 33554432
    SNMPv2-SMI::enterprises.11.2.3.1.1.11.0 = Gauge32: 33554432
    SNMPv2-SMI::enterprises.11.2.3.1.1.12.0 = Gauge32: 33554432
    SNMPv2-SMI::enterprises.11.2.3.1.1.13.0 = Counter32: 31987939
    SNMPv2-SMI::enterprises.11.2.3.1.1.14.0 = Counter32: 73671656
    SNMPv2-SMI::enterprises.11.2.3.1.1.15.0 = Counter32: 3000667491
    SNMPv2-SMI::enterprises.11.2.3.1.1.16.0 = Counter32: 0
    This is the TOP taken inside the server on that I need the info from:
    System: HOSTAMEEEE Thu Jul 5 13:24:26 2018
    Load averages: 0.24, 0.25, 0.26
    132 processes: 119 sleeping, 12 running, 1 zombie
    Cpu states:
    CPU LOAD USER NICE SYS IDLE BLOCK SWAIT INTR SSYS
    0 0.25 29.1% 0.0% 4.4% 66.5% 0.0% 0.0% 0.0% 0.0%
    1 0.23 13.2% 0.0% 8.0% 78.8% 0.0% 0.0% 0.0% 0.0%
    avg 0.24 21.2% 0.0% 6.2% 72.7% 0.0% 0.0% 0.0% 0.0%
    Does anyone know what unit are the SNMP express on?? I need this on zabbix but in a human readable format, is possible "%".
    Thank you
    Karina
  • karmukis
    • Aug 2014
    • 37
    Anyone, any ideas that may guide me? The snmp check is returning that strange value, which I believe surely are express on cycles or ticks, does anyone know how to translate to %, Is the value on ticks or cycles?
    I would really appreciate the help.
    Karina
