Buying GSM module
  • VirtuaWin
    • Jul 2018
    Buying GSM module
    I want to buy a GSM module to use with Zabbix.
    I saw the ones on the Zabbix documentation, but those are very old and I can't find one that isn't used or refurbished.
    Can you recommend me a good one that works with Zabbix?
    Thanks.
  • Colttt
    • Mar 2009
    • 878
    I recommend a Standard UMTS- Stick that works with Linux, plug-in in you srver and you're done.
    Other solution, buy a SingleBoardComputer and a UMTS-Stick, configure it,and install usbip[1] so you can connect zabbix to this umts stick no matter where on which (bare-metal)machine is zabbix running
    [1] https://www.kernel.org/doc/readme/to...b-usbip-README
    Debian-User
    Sorry for my bad english
