How to print TRIGGER description in message
  • acasari
    • Jan 2014
    • 11
    I would like to include a trigger description (I filled the description attribute in the trigger definition) in a message.
    How do I refer to it in a Condition? I only found {TRIGGER.NAME}, is there any sort of {TRIGGER.DESCRIPTION} ?
    Thanks in advance.
  • thomphi
    • Feb 2014
    • 74
    I think "TRIGGER.COMMENT" works.
    • jan.garaj
      • Jan 2010
      • 506
      Trigger description. Supported since 2.0.4.
      Starting with 2.2.0, all macros supported in a trigger description will be expanded if {TRIGGER.DESCRIPTION} is used in notification text.
      {TRIGGER.COMMENT} is deprecated.
      • acasari
        • Jan 2014
        • 11
        Thanks for the help!
