Hi
I have setup a UserParameter once before to get bandwidth usage on a partictular port using pmacct, wich worked well but It was along time ago, and I cant rememeber how I did it ..
Hope fully some can tell me what I have done wrong ....
1) I added an entry to zabix_agentd.conf
UserParameter=porttraf[*],/usr/local/bin/porttraf.pl $1 $2
2) I created a perl script to pass the number to pmacct.
#!/usr/bin/perl
use strict;
my $port = @ARGV[0];
my $result = `pmacct -c src_port,dst_port -N "*,$port;$port,*" -S -p /tmp/traf.pipe -r`;
print "$result";
3) I created an item with the following settings..
Description Port traffic PORT 80
Type ZABBIX agent (active)
Key porttraf[80]
Type of information Numeric (float)
Units Bps
Use multiplier Do not use
Update interval (in sec) 60
Keep history (in days) 7
Keep trends (in days) 365
Status Monitore
Store value Delta (speed per second)
Applications None
but I get no results ...
Many Thanks
Gregory Machin
[email protected]
#!/usr/bin/perl
use strict;
print "$result";
Key porttraf[80]
Units Bps
Status Monitore
Applications None
Many Thanks
Gregory Machin
[email protected]
