EventLog resolved ?
  • thomphi
    • Feb 2014
    • 74
    EventLog resolved ?
    Hello everyone !
    I have a little question, I have configured EventLog (item, trigger, action) and I want to know when zabbix considers the problem "resolved"?
    Because the problem still in my dashboard...
    Zabbix remove the problem after a couple of days ? Or I can fix it ?
    (In "Action" I have uncheck "Recovery message")
    PS : Picture below
    Thank's
    Thomas
    Bonjour à tous !
    J'ai une petite question, j'ai configuré EventLog (item, trigger, action) et je voulais savoir quand Zabbix considère que le problème est résolu ?
    Parce que le problème reste sur le dashboard.
    Est ce que Zabbix retire le problème tout seul ou au bout de quelque jours ? Ou je peux le faire manuellement ?
    (Dans "Action" j'ai décoché la case "Recovery Message")
    Merci par avance,
    Thomas
  • tsalle
    • Oct 2012
    • 79
    It depends on your trigger expression.
    if it's like
    {host:log[path].logseverity()}>N
    It will stay in problem until the next log entry.
    What is your trigger expression ?
    PS : je répond en anglais, c'est plus simple pour tout le monde :P
    • thomphi
      • Feb 2014
      • 74
      My trigger is like this :
      {DGOBIN:eventlog[Application].logseverity(0)}=4
      D'accord, merci
      • tsalle
        • Oct 2012
        • 79
        What is the last event severity in your windows event log ?
        Have you tried to generate an information message.
        What is the frequency of your item refresh ?
        Quelle version de Zabbix utilises tu ?
        • thomphi
          • Feb 2014
          • 74
          I don't have access to the server today... So I don't know the last severity.
          "Have you tried to generate an information message." In other words ?
          And my update interval is 30 sec.
          J'utilise Zabbix Appliance en 2.0
          • thomphi
            • Feb 2014
            • 74
            Ok, Zabbix remove the problem after couple of hours(2h, 5h, it depends...). But why? What is the reason?
