Trigger question
  • steff
    • Jul 2006
    • 19
    Trigger question
    I would like to receive notification when a failure gets repaired.
    For example :
    - an item activates a trigger for some failure ( e.g. icmp-ping fails for 5 times every 30 secs. )
    - the trigger send an email of notification
    - the failure ends ( icmp-ping reachs the host )
    - as zabbix detects an item previously triggered turns in a correct state it activates
    an action that sends an email telling that everything went ok
    Is it possible?
    I've tried with trigger dependencies but if I set the ping trigger as dependency it
    doesn't activate actions when it's verified ...
  • sauron
    • Jan 2005
    • 215
    Yep. Set two action. One run when trigger ON two run when trigger OFF.
    • steff
      • Jul 2006
      • 19
      Now I uderstand !
      1- trigger is ON when there is a transaction from FALSE to TRUE
      while
      2- trigger is OFF when there is a transaction from TRUE to FALSE
      (this second point wasn't to me very clear)
      Thank you very much,
      steff
