How to monitor Kannel SMS Gateway by Zabbix
  • humayunshafiq
    • Dec 2012
    I am kind a new to zabbix i need to monitor my SMS gateway Kannel service through zabbix, i cant find any usable help.
    Thank You in advance
  • aib
    • Jan 2014
    • 1615
    1) Decide which parameters you would like to monitor.
    - Service UP/DOWN
    - SMS/per minutes sent/received
    - How many times the word USA was used inside of SMS (jk
    2) Then, check the instruments: how you can get that numbers/parameters:
    - SNMP
    - internal scripts
    - specific program from manufacturer
    - CLI command
    3) Plan your list of Items, triggers, graphs for the list of parameters which you selected to list of important quantities.
    4) Create the Items and scripts/SNMP/UserParameters which will collect the data from your SMS Gateway.
    5) Share your data with Zabbix community and get the new achievements.
    BTW, ask more precise questions. It looks that not many people works with Kannel SMS Gateway and even fewer know about Zabbix.
    You are the pioneer!
    Sincerely yours,
    Aleksey
    • humayunshafiq
      • Dec 2012
      Thanks for the reply ,
      what i am looking for now is to check status of each SMSC connections through zabbix.
      Please help its much needed
      Thanks in advance
