Hello, I am a noob with Zabbix. I am setting up some web scenarios in Zabbix 3.4 to test a rest based application workflow with Zabbix. The responses are in JSON format and I am trying to form a regex that will extract a value an initial login
I am getting an error in the zabbix console from my parse
Error: error in step variables "{token}=regex:"access_token": "([0-9a-z-])"": cannot extract the value of "{token}" from response
A typical response is
"access_token": "576fb0e1-0d99-4f7a-a1d7-d11d35aXXXX",
"token_type": "Bearer",
"expires_in": 3214,
"refresh_token": "9a537f10-e2cb-476a-a296-f2fa885XXXX",
I am trying to debug this error but having problems. Is there a good website to validate my regex? Can we increase the logging in zabbix around web scenario to see what is happening or does any one have suggestion on the regex.
Any help would be greatly appreciated.
Thank you in advance
"expires_in": 3214,
