regex of time
  • albertosierra
    • Feb 2014
    regex of time
    I'd like to check if the last value of an item was generated in the first 5 minutes after an even hour to trigger an alert. I tried to use something like:
    {template:item].time(0).regexp(^\d[02468][0][0-5])}=0
    when saving it returns an error: Incorrect trigger expression
    is this something that can be done in triggers is there a better way to acomplish it?
  • aib
    • Jan 2014
    • 1615
    I don't have a solution but just confused of your reg.exp.
    Why you use the wrong slash?
    for me it has to looks like
    ^\d[02468][0][0-5]
    Sincerely yours,
    Aleksey
    • albertosierra
      • Feb 2014
      that was a typo. when i created the post. the regexp was correctly added to the trigger
