zabbix proc.num[] and POSIX regular expressions
  • gesgarcia
    • Oct 2016
    I'm trying to get the total number of processes what start whith the string "var"
    I'm trying to use a query like this:
    zabbix_get -s <my_host_IP> -p 10050 -k "proc.num[var*]"
    but returns 0
    If I run those queries:
    zabbix_get -s <my_host_IP> -p 10050 -k "proc.num[var1]"
    zabbix_get -s <my_host_IP> -p 10050 -k "proc.num[var7]"
    zabbix_get -s <my_host_IP> -p 10050 -k "proc.num[var3]"
    they return 1
    Do you know if proc.num supports this kind of expressions (like *, ^, $) ?
    Thank you for your help
    Regards
  • jan.garaj
    • Jan 2010
    • 506
    No, but you can use cmdline filer: https://www.zabbix.com/documentation...s/zabbix_agent
    • gesgarcia
      • Oct 2016
      Originally posted by jan.garaj
      Good!
      Thank you so much jan.garaj
      It works perfectly
