ICMP Ping from zabbix agent
  • truongk4a3
    • Aug 2018
    Dear All
    I need configure ping to the IP address from Zabbix agnet in MS Window.
    Please let me now how to configure it ?
    My system runing Zabbix 3.4
    Thanks so much !
  • truongk4a3
    • Aug 2018
    My Problem is solved
    1. On machine zabbix agent , create script ping in file.dat with content bellow:
    echo off
    set MyServer=ip address host
    %SystemRoot%\system32\ping.exe -n 1 %MyServer% >nul
    echo %errorlevel%
    2. Add User Prameter in file zabbix agent conf : UserParameter=key,path to file.dat
    3. Create item and triger in zabbix server:
    Type: zabbix agent
    Key: is key created at step 2
