Installing zabbix with Oracle DB
  • sandeepkumar
    • Jul 2018
    Hi all, I am New to Oracle RAC, I'm installing Zabbix 3.2.1 I run a demo without a problem using MySQL but know I'm configuring a more proper server for this using our Oracle instance.
    I'm following the official guide here https://www.zabbix.com/documentation...all/db_scripts but it seems to be incorrect.
    First I had to change the images.sql file to change the target directory to /tmp/zabbix_images instead of the default one. Then I had to give a couple of grant to zabbix user on the db like "create any directory" and "drop any directory".
    But also then, when I try to run the @images.sql file I got the following compilation errors:
    Warning: Procedure created with compilation errors. LOAD_IMAGE(1,1,'Cloud_(128)','png_modern/Cloud_(128).png'); * ERROR at line 2: ORA-06550: line 2, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 2, column 2: PL/SQL: Statement ignored ORA-06550: line 3, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 3, column 2: PL/SQL: Statement ignored ORA-06550: line 4, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 4, column 2: PL/SQL: Statement ignored ORA-06550: line 5, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 5, column 2: PL/SQL: Statement ignored ORA-06550: line 6, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 6, column 2: PL/SQL: Statement ignored ORA-06550: line 7, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 7, column 2: PL/SQL: Statement ignored ORA-06550: line 8, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 8, column 2: PL/SQL: Statement ignored ORA-06550: line 9, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 9, column 2: PL/SQL: Statement ignored ORA-06550: line 10, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 10, column 2: PL/SQL: Statement ignored ORA-06550: line 11, column 2: PLS-00905: object ZABBIX.LOAD_IMAGE is invalid ORA-06550: line 11, column 2: PL/SQL: Statement ignored How can I solve this? Or can I just ignore it being only part of the lines? Thanks, sandeep, Oracle Admin
  • Hernandes Martins
    • Apr 2011
    • 901
    hi
    Why Oracle?
    I recomend Mysql or Postgres every moment.
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
