Problems installing Zabbiх on CentOS
  • unoc_u34
    • Jul 2018
    Hi everybody! I install Zabbix on CentOS 7.5.
    There are:
    Apache 2.4.39
    PPP 7.2.8 (PHP, PHP-MySQL)
    MySQL 8.0.12
    When installing, I used the source https://www.zabbix.com/documentation...es/rhel_centus
    During the installation of zabbix-web-muscle I get the following error:
    -> Processing Dependency: php-mysql for package: zabbix-web-mysql-3.4.12-1.el7.noarch
    Package php-mysql-5.4.16-45.el7.x86_64 is obsoleted by php-mysqlnd-7.2.8-1.el7.remi.x86_64 which is already installed
    -> Finished Dependency Resolution
    Error: Package: zabbix-web-mysql-3.4.12-1.el7.noarch (zabbix)
    Requires: php-mysql
    Available: php-mysql-5.4.16-45.el7.x86_64 (base)
    php-mysql = 5.4.16-45.el7
    Available: php-mysqlnd-5.4.16-45.el7.x86_64 (base)
    Available: php-pecl-mysql-1.0.0-0.17.20160812git230a828.el7.remi.7.2.x86_64 (remi-php72)
    php-mysql = 1: 1.0.0
    Installed: php-mysqlnd-7.2.8-1.el7.remi.x86_64 (@ remi-php72)
    Not found
    Available: php-mysqlnd-7.2.7-1.el7.remi.x86_64 (remi-php72)
    Not found
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles - nudist
    Tell me how to fix this. Thanks in advance
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi Uno
    Folow the steps the documentation for CentOS 7 for instalation zabbix
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    After
    Install Mariadb server
    yum install mariadb-server
    systemctl enable mariadb-server
    systemctl start mariadb-serve
    After create a database with steps from before e folow the link documentation
    Look the Selinux, if enable or enforcing , change to disable and reboot your system
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Atsushi
      • Aug 2013
      • 2028
      The Zabbix official package for RHEL 7(CentOS 7) is to be built using RHEL 7(CentOS 7) standard package.
      If you are having problems with package dependencies, please choose one of the following.
      - Restore PHP to standard version
      - Ignore package dependencies and install the necessary packages with the rpm command
      As a precaution, PHP 5.4 uses php-mysql, but PHP 7.2 will require php-mysqlnd.
