How can I import an image xml file to zabbix 3.4.11 ? Is it possible? The API lists images as possibility to import/export.....but does not provide a link to it:
I was able to import a xml image file with zabbix 3.2 using the Zabbix API. Now that I updated to 3.4.11, the request comes out 'empty'. Maybe the schema for the images xml has changed? Where can I find this in the Zabbix API 3.4 documentation?
Thanks,
Thanks,
