odbc installation for low level discovery with proxy
  • andrea.g.els
    • Jan 2018
    • 18
    I'm reading about low level discovery with ODBC, and I need to do LLD on one host monitored through a proxy (No direct monitor , different DC )
    Where i must install the ODBC package ? On the proxy or on the mysql host ?
    checked
    and
    but doesn't shed light
  • LenR
    • Sep 2009
    • 1011
    I'm pretty sure on the proxy
    • Hernandes Martins
      • Apr 2011
      • 901
      Yes, the best practices on the proxy.
      __
      Att.
      Skype: hernandss
      Telegram: @MrHernandes
      Español
      Português
      • andrea.g.els
        • Jan 2018
        • 18
        ok , done and tested with isql from the proxy :
        [root@proxy zabbix]# sudo -u  zabbix  isql -v DSN
        | Connected!                            |
        | sql-statement                         |
        | help [tablename]                      |
        | quit                                  |
        created the template , and assigned to the host (which is managed by the proxy).
        From the server's log I can find those entries :
          6695:20180814:105715.947 item "dbhost:db.odbc.discovery[discovery,DSN]" became not supported: Cannot connect to ODBC DSN:[SQL_ERROR]:[HY000][2003][[unixODBC][MySQL][ODBC 5.2(w) Driver]Can't connect to MySQL server on '10.14.100.30' (13)]|
        any clue?
        there is something else needed to put the proxy in charge for the discovery , except the "managed by proxy" in the client ?
        • andrea.g.els
          • Jan 2018
          • 18
          additional note : despite having interval set to 30s for this rule , I've seen this message only once
          • Hernandes Martins
            • Apr 2011
            • 901
            look (13) = permision denied
            run test
            # isql DSN user password
            or
            # query | isql DSN user password
            Follow the examples
            Search commands isql with queries.
            Regards
            __
            Att.
            Skype: hernandss
            Español
            Português
            • andrea.g.els
              • Jan 2018
              • 18
              Hello Hernandes,
              the permission denied hint (also if not 100% accurate) ringed a bell.
              It was a selinux missing permission on the proxy host
              zabbix_server.log:  6695:20180814:105715.947 item "HOST:db.odbc.discovery[DISCOVERY,DSN]" became not supported: Cannot connect to ODBC DSN:[SQL_ERROR]:[HY000][2003][[unixODBC][MySQL][ODBC 5.2(w) Driver]Can't connect to MySQL server on 'IP' (13)]|
              zabbix_server.log:  6698:20180814:132513.848 discovery rule "HOST:db.odbc.discovery[DISCOVERY,DSN]" became supported
              ausearch -c 'zabbix_proxy' --raw | audit2allow -M my-zabbixproxy
              semodule -i my-zabbixproxy.pp
              setsebool -P zabbix_can_network 1
              fixed the issue
              It's still unclear to me why the discovery run after 2 hrs and half instead of 30 seconds as configured
              • Hernandes Martins
                • Apr 2011
                • 901
                Wow
                Great job!!!
                __
                Att.
                Skype: hernandss
                Español
                Português
                • DmitryL
                  • May 2016
                  • 278
                  Keep in mind that proxy gets fresh configuration from the server only once an hour by default.
