Azure VM network interface monitoring Number of Bytes received/sent
  • dragan979
    • Apr 2018
    • 49
    Click image for larger version  Name:	1.PNG Views:	1 Size:	13.6 KB ID:	364310
    I don't know how to create trigger from these values
    Per MS: Network OUT:The number of bytes out on all network interfaces by the Virtual Machine(s) (Outgoing Traffic)
    Network IN: The number of bytes received on all network interfaces by the Virtual Machine(s) (Incoming Traffic)
    Click image for larger version  Name:	3.PNG Views:	1 Size:	143.2 KB ID:	364312
    Click image for larger version  Name:	2.PNG Views:	1 Size:	14.2 KB ID:	364311
  • dragan979
    • Apr 2018
    • 49
    i think it's solved: {azure template:azure.vm.network_in.pt5m["{#ID}",common].last()}>20M raise alert if incoming traffic is > 20 M
