Hi Guys
For our new infrastructure with a new Hyper-V Server I tried to configure our Zabbix server that it would discover and monitor all the new VMs automatically. Therefore I used the templates from https://github.com/ameiji/Zabbix-HyperV-Templates which work perfectly to discover the hosts and items.
Unfortunately I do have a lot of gaps in the data streams which you can see in the following image.
In my opinion the reason is that either the zabbix server or the agent on the Hyper-V server can't handle the the requests because of the high number of unreachable poller processes.
In the server log I can see that the "Zabbix aget item "...." on host "..." failed: first networkerror...
I changed the number of StartPollers, the Timeout Time on the server and client, changed the hostname to an IP, measured the time for the shell commands on the Hyper-V server but I never found a solution to get rid of the problem.
As I can't see the wood for the trees could you help me with this issue?
Cédric
Cédric
