Inverse web monitoring
  • cristian.chavez
    • Aug 2018
    Hi to all;
    For our NOC Team, we need an alert to advice that a service IS active.
    For this monitoring item we have two nodes, in fact; one of the nodes is active and operating and the second node is down, but we need to generate an alert if this second node is active.
    In the web monitoring configuration, the second node shows the error:
    Couldn't connect to server: couldn't connect to host. How i can configure the web monitoring for this item?, i think that the process should be made into the steps in web monitoring, but i cannot build the logic to make this.
    Regards from Colombia.
    Cristian.
