Understanding sending proxy heartbeat to Zabbix
  • AlBoPo
    • Aug 2018
    • 23
    I'm new to Zabbix and I'm looking on how to write a Zabbix agent for a specific hardware.
    So first I'm trying to Simply send an heartbeat.
    I declared my Template and a corresponding Element named `heartbeat` of a type `Zabbix trapper` with a corresponding trigger where I wrote the expression as follow (FX30 is the name of my Template):
    {FX30:heartbeat.nodata(20m)}=1
    So on the dashboard, I can see that my hosts using this Template are currently showing this problem which seems to be as expected.
    So now is the part where I don't really understand everything.
    I wrote a program on my remote target which is supposed to send its heartbeat every 10 minutes and I send the following json string:
    '{"request":"proxy heartbeat","host":"LL709601401410"}'
    Maybe I forgot the version as I just saw in the doc.
    And the server responds:
    { "response": "success" } As expected.
    Anyway, the hosts are still displaying the problem but I think I don't send what they are waiting for.
    In fact in the doc here (https://www.zabbix.com/documentation...ndix/protocols), as I created a Zabbix trapper type of trigger, I wonder if I wouldn't have to use Sender data as explained here (https://www.zabbix.com/documentation.../items/trapper).
    So I tried, I verified that I actually send the request as explained:
    { "request":"sender data", "data":[ { "host":"LL709601401410", "key":"heartbeat", "value":"1" } ] }
    Zabbix answered {"response":"success","info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000031"} .
    Well, ok but what is the reason for the failure??
    I looked at the latest data:
    But in fact I don't understand if it received something and when and which between all my tries caused this and even if it was caused by somthing sent....
    Can you explain me what I didn't understand please?
    Alain
    Using version 3.4.12
