Check my last comment.
protocol request info
DmitryL I think you touched what I didn't understand!
In fact I try to add additional data to an exisiting custom agent wrote by another team I don't have any contact anymore with.
Up to now, they collect snmp data, and send it to zabbix_server_ip:10051 and they send a JSON string like:
{"request":"history data","host":"LL709601401410","data":[{"host":"4567","key":"zabbix[host,snmp,available]","clock":1534944976,"ns":924934000,"value":"2"},{ "host":"4567","key":"upsAlarmsOnUPS","clock":15349 44976,"ns":924934000,"value":""},{"host":"4567","k ey":"zabbix[host,snmp,available]","clock":1534945062,"ns":581188000,"value":"2"},{ "host":"4567","key":"upsAlarmsOnUPS","clock":15349 45062,"ns":581188000,"value":""},{"host":"4567","k ey":"zabbix[host,snmp,available]","clock":1534953475,"ns":576634000,"value":"2"},{ "host":"4567","key":"upsAlarmsOnUPS","clock":15349 53475,"ns":576634000,"value":""},{"host":"4567","k ey":"zabbix[host,snmp,available]","clock":1535016082,"ns":821557000,"value":"2"},{ "host":"4567","key":"upsAlarmsOnUPS","clock":15350 16082,"ns":821557000,"value":""},{"host":"4567","k ey":"zabbix[host,snmp,available]","clock":1535024247,"ns":434162000,"value":"2"},{ "host":"4567","key":"upsAlarmsOnUPS","clock":15350 24247,"ns":434162000,"value":""}],"clock":1535024291,"ns":0}
These data are well received and processed by Zabbix server.
So I hoped to use the same connection channel to send my JSON string. And for a reason I don't understand but which could be what you suspect, that don't works.
So I'd like to understand why SNMP data are succesfully sent to that channel for that host and why mine are not!
Just my assumption that host which received SNMP data is monitored by Zabbix server directly, not by the proxy. Then it should work.
In your case host LL709601401410 is monitored through the proxy LL709601401410 (You should see it in Administration -> Proxies).
If that is true, then all data should be sent to the Proxy IP address, and the proxy will forward it to the Server.
If your host is monitored by the proxy, but you are sending data directly to the Server - it will not work.
So the proxies are defined like that: https://i.imgur.com/EuFW5AZ.png
the ZS110 is the host where SNMP data are defined: https://i.imgur.com/QW2WD05.png
Both LL709601401410 and ZS110 seem to be monitored by the LL709601401410 proxy no?
Proxy IP address ??? AFAIK, these proxies are software/virtual entities created by zabbix itself no?Last edited by AlBoPo; 23-08-2018, 13:57.Comment
They are using "request" : "history data" which basically imitates proxy sending data to server.
However, you are using "request":"agent data" which imitates agent sending data to proxy/server
it still should work, but you need to change IP address in your C script from Zabbix server IP to Zabbix proxy IP.Comment
If you want to use history data:
If you want to use agent data:Code:telnet <zabbix_server_ip> 10051 {"request":"history data","host" : "<proxy_name>", "clock":"1534953473","ns":"564379000","data":[{"host":"<hostname>","key":"test","value" :5,"clock":1534953473,"ns":564379000}]}
Code:telnet <zabbix_proxy_ip> 10051 {"request":"agent data","data":[{"host":"test","key":"test","value" :1,"clock":1534953473,"ns":564379000}]}Comment
In fact as I said, proxies and server are running on the same machine but
{"request":"history data","host" : "<proxy_name>", ...
is certainly what I didn't understand here. I going to test it like that.
Anyway, if I cannot address the proxy through a different IP, how to do?
And in fact if I look at the proxy creation, I do not look any IP address specification in Zabbix 3.4.7: https://i.imgur.com/o0GhX9f.png
PS: I tried the "history data" request and it works; Thanks a lot. Now, for my knowledge, I did like if there is any way to use "agent data" in my configuration?
