If there is a better solution to my problem than what I am trying to do, please let me know.
We are going to start using LLD for our file systems. The template we had previously been using had triggers set differently for '/' partitions than every other partition. Since the LLD discovers all of the partitions now, is there a way to distinguish between the discovered file systems?
The best example that I can think of is something like this...
...and this for everything else...
{Template_OS_Linux_v2:vfs.fs.size[{#FSNAME},pfree].last(0)}<10 & {#FSNAME}="/"
{Template_OS_Linux_v2:vfs.fs.size[{#FSNAME},pfree].last(0)}<6 & NOT{#FSNAME}="/"
