Monitor DAT file
  • KristofL
    • Feb 2014
    Monitor DAT file
    Hi there,
    To monitor Symantec Endpoint Protection, i'm wanting to extract the date value of the definfo.dat file.
    The file has the following contents:
    [DefDates]
    CurDefs=20140221.009
    I want the output to be 20140221
    and my item (Zabbix Active) is defined like this
    vfs.file.regexp["C:\Program Files\Common Files\Symantec Shared\VirusDefs\definfo.dat","^([0-9]){8}$",,0,3,\1]
    But that doesn't seem to work (I don't really have much experience with regular expressions)
    Can someone help me to solve this issue?
    Thank you in advance all,
    Br,
    Kristof
  • luka
    • Mar 2014
    Try with vfs.file.regexp["C:\Program Files\Common Files\Symantec Shared\VirusDefs\definfo.dat","([0-9]{8})",,,,\1]
    Best regards
