Discover at 75%
  • newbietozabbix67
    • Aug 2018
    • 9
    Discover at 75%
    No doubt a newbie question, too. Since installing and firing up zabbix, I have had a 'Zabbix discoverer processes more than 75% busy' problem on the dashboard.
    I acknowledged it, and even set Discoverers to 0 in the /etc/zabbix/zabbix_server.conf (and of course, restarted zabbix)...
    newbietozabbix67@zabbix ~]$ sudo grep -i discover /etc/zabbix/zabbix_server.conf
    ### Option: StartDiscoverers
    #    Number of pre-forked instances of discoverers.
    StartDiscoverers=0
    But still, it's there.
    Can someone tell me how to get rid of this ?
    Thanks.
  • Linwood
    • Dec 2013
    • 398
    Find out how many you need and set the config to more than that. You can see how many it is using from the history.
    • newbietozabbix67
      • Aug 2018
      • 9
      I'm not really sure what that means. How many? This is to detect an ESXi host, and not VMs.
      EDIT : Sorry, wrong post, and wrong thread. I activated the Discoverers and this did make the message disappear. Thanks. :-)
      • ali.mousavi.khatat
        • Feb 2022
        i just disable discovery ruls in configuration
        and restart zabbix_server services in ubuntu:
        $ service zabbix-server restart
