Hi, I just installed zabbix server for one week. Major goal is monitor near 100 device, including some Router&Switch and few servers.
I am trying to calculate a item polled by SNMP,
snmpwalk read value as follows:
[root@zabbix ~]# snmpwalk -v 2c -c xxxx@wgzx 203.xxx.xxx.xxx 1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519
SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.5.519 = INTEGER: -268
[root@zabbix ~]# snmpwalk -v 2c -c xxxx@wgzx 203.xxx.xxx.xxx .1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519
[root@zabbix ~]# snmpwalk -v 2c -c xxxx@wgzx 203.xxx.xxx.xxx enterprises.2636.3.60.1.1.1.1.5.519
Then are all reading same object,and I need calculate the value "-268" into "-22.68" ,formula is :-268/100-20='-22.68'
like when I use this command on router:
RE0> show interfaces diagnostics optics xe-0/1/1
Physical interface: xe-0/1/1
Laser rx power : 0.0054 mW / -22.68 dBm
I tried the following:
key:test
Formula:last("enterprises.2636.3.60.1.1.1.1.5.519" )/100-20
key:test
Formula:last(".1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519 ")/100-20
key:test
Formula:last("1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" )/100-20
key:test
Formula:0.01*last("1.3.6.1.4.1.2636.3.60.1.1.1.1.5 .519")-20
key:1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519
And this is zabbix_server.log following:
11179:20180829:011649.657 item "JXQ-960-2:test" became not supported: Cannot evaluate function "last()": item "JXQ-960-2:enterprises.2636.3.60.1.1.1.1.5.519" does not exist.
11179:20180829:013149.685 item "JXQ-960-2:test" became not supported: Cannot evaluate function "last()": item "JXQ-960-2:1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" does not exist.
11181:20180829:013450.345 item "JXQ-960-2:test" became not supported: Cannot evaluate function "last()": item "JXQ-960-2:1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" does not exist.
11175:20180829:013801.319 item "JXQ-960-2:test" became not supported: Cannot evaluate function "last()": item "JXQ-960-2:.1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" does not exist.
11175:20180829:043632.250 error reason for "JXQ-960-2:.1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" changed: Cannot evaluate expression: "Cannot evaluate function "last()": item "JXQ-960-2:.1.3.6.1.4.1.2636.3.60.1.1.1.1.5.519" not supported.".
11175:20180829:051934.377 item "JXQ-960-2:test" became not supported: Cannot evaluate function "last()": item "JXQ-960-2:enterprises.2636.3.60.1.1.1.1.5.519" does not exist.
Can anyone know how to correct this? thanks!
key:test
key:test
key:test
key:test
