Calculated item based on a trigger
  • mbribeiro@gmail.com
    • Jun 2018
    • 13
    HI, I would like to know if is possible to create a calculated item representing the trigger status of another item ? For example, this new calculated item would value 0 if the trigger is not triggered and 1 otherwise.
    In case it is not possible another approach would be a calculated item with a comparator, for example {last(anotherkey) > 20}. If I could somehow map this boolean logic to zero or one in a calculated item would be another way to solve my problem.
    Thanks in advance.
  • DmitryL
    • May 2016
    • 278
    What's the use case for that? You can get trigger status in 1 or 0 with API.
    • Semiadmin
      • Oct 2014
      • 1626
      Yes, you may use last("anotherkey")>20 in calculated item formula. It returns 0 or 1.
        [email protected] commented
        Great, that worked. Thank you Dmitryb as well.
