Hi, I have 4 trigger prototypes that will go off when any of the expressions are matched. So the desired state would be that if any of the 4 triggers went off, none of the others will send alarms.
Additionally would be nice to have within a trigger "If any of the instance go off, don't alarm for the others". Since I have 6 VRRP instances within the same trigger prototype, I am receiving 6 alerts when machine goes down, and then other triggers jump in as well.
The template I am using is the one provided by https://share.zabbix.com/cat-app/hig...eepalived-snmp
Thanks.
Thanks.
