Dear All,
I've struggled a lot over this. Couldn't find solutions. Required expert help.
I'm working on Huawei Switches. I'm monitoring Optical interface (SFP) Power(Voltage) Tx/Rx.
Requirements :
I want to show interface and interface description in "item name".
e.g
Optical Interface XGigabitEthernet0/0/4(To switch first floor): SFP Optical Rx
Problem:
I'm not able to get description of interface because discovery index {#SNMPINDEX} is not same in OID.
i.e
index for "XGigabitEthernet0/0/2" interface is 67321998 while index for description is 30
Interface Name OID.
snmpwalk -v 2c -Ofs -c <Communication String> <IP> .1.3.6.1.2.1.47.1.1.1.1.7
mib-2.47.1.1.1.1.7.67305550 = STRING: "GigabitEthernet0/0/1"
mib-2.47.1.1.1.1.7.67305614 = STRING: "GigabitEthernet0/0/2"
mib-2.47.1.1.1.1.7.67305678 = STRING: "GigabitEthernet0/0/3"
mib-2.47.1.1.1.1.7.67305742 = STRING: "GigabitEthernet0/0/4"
mib-2.47.1.1.1.1.7.67305806 = STRING: "GigabitEthernet0/0/5"
mib-2.47.1.1.1.1.7.67305870 = STRING: "GigabitEthernet0/0/6"
mib-2.47.1.1.1.1.7.67305934 = STRING: "GigabitEthernet0/0/7"
mib-2.47.1.1.1.1.7.67305998 = STRING: "GigabitEthernet0/0/8"
mib-2.47.1.1.1.1.7.67306062 = STRING: "GigabitEthernet0/0/9"
mib-2.47.1.1.1.1.7.67306126 = STRING: "GigabitEthernet0/0/10"
mib-2.47.1.1.1.1.7.67306190 = STRING: "GigabitEthernet0/0/11"
mib-2.47.1.1.1.1.7.67306254 = STRING: "GigabitEthernet0/0/12"
mib-2.47.1.1.1.1.7.67306318 = STRING: "GigabitEthernet0/0/13"
mib-2.47.1.1.1.1.7.67306382 = STRING: "GigabitEthernet0/0/14"
mib-2.47.1.1.1.1.7.67306446 = STRING: "GigabitEthernet0/0/15"
mib-2.47.1.1.1.1.7.67306510 = STRING: "GigabitEthernet0/0/16"
mib-2.47.1.1.1.1.7.67306574 = STRING: "GigabitEthernet0/0/17"
mib-2.47.1.1.1.1.7.67306638 = STRING: "GigabitEthernet0/0/18"
mib-2.47.1.1.1.1.7.67306702 = STRING: "GigabitEthernet0/0/19"
mib-2.47.1.1.1.1.7.67306766 = STRING: "GigabitEthernet0/0/20"
mib-2.47.1.1.1.1.7.67306830 = STRING: "GigabitEthernet0/0/21"
mib-2.47.1.1.1.1.7.67306894 = STRING: "GigabitEthernet0/0/22"
mib-2.47.1.1.1.1.7.67306958 = STRING: "GigabitEthernet0/0/23"
mib-2.47.1.1.1.1.7.67307022 = STRING: "GigabitEthernet0/0/24"
mib-2.47.1.1.1.1.7.67321934 = STRING: "XGigabitEthernet0/0/1"
mib-2.47.1.1.1.1.7.67321998 = STRING: "XGigabitEthernet0/0/2"
mib-2.47.1.1.1.1.7.67322062 = STRING: "XGigabitEthernet0/0/3"
mib-2.47.1.1.1.1.7.67322126 = STRING: "XGigabitEthernet0/0/4"
Interface Optical power Voltage OID.
snmpwalk -v 2c -Ofs -c <Communication String> <IP> 1.3.6.1.4.1.2011.5.25.31.1.1.3.1.8
enterprises.2011.5.25.31.1.1.3.1.8.67305550 = INTEGER: 111
enterprises.2011.5.25.31.1.1.3.1.8.67305614 = INTEGER: 50
enterprises.2011.5.25.31.1.1.3.1.8.67305678 = INTEGER: 117
enterprises.2011.5.25.31.1.1.3.1.8.67305742 = INTEGER: 22
enterprises.2011.5.25.31.1.1.3.1.8.67305806 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67305870 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67305934 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67305998 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306062 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306126 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306190 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306254 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306318 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306382 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306446 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306510 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306574 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306638 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306702 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306766 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67306830 = INTEGER: 167
enterprises.2011.5.25.31.1.1.3.1.8.67306894 = INTEGER: 0
enterprises.2011.5.25.31.1.1.3.1.8.67306958 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67307022 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67321934 = INTEGER: 27
enterprises.2011.5.25.31.1.1.3.1.8.67321998 = INTEGER: 43
enterprises.2011.5.25.31.1.1.3.1.8.67322062 = INTEGER: -1
enterprises.2011.5.25.31.1.1.3.1.8.67322126 = INTEGER: -1
Interface description.
snmpwalk -v 2c -Ofs -c <Communication String> <IP> 1.3.6.1.2.1.31.1.1.1.18
ifAlias.1 = STRING:
ifAlias.2 = STRING:
ifAlias.3 = STRING:
ifAlias.4 = STRING:
ifAlias.5 = STRING: XXXXXXXXXXXXXXXXXXXX
ifAlias.6 = STRING: XXXXXXXXXXXXXXXXXXXX
ifAlias.7 = STRING: XXXXXXXXXXXXXXXXXXXX
ifAlias.8 = STRING:
ifAlias.9 = STRING:
ifAlias.10 = STRING:
ifAlias.11 = STRING:
ifAlias.12 = STRING:
ifAlias.13 = STRING:
ifAlias.14 = STRING:
ifAlias.15 = STRING:
ifAlias.16 = STRING:
ifAlias.17 = STRING:
ifAlias.18 = STRING:
ifAlias.19 = STRING:
ifAlias.20 = STRING:
ifAlias.21 = STRING:
ifAlias.22 = STRING:
ifAlias.23 = STRING:
ifAlias.24 = STRING:
ifAlias.25 = STRING: XXXXXXXXXXXXXXXXXXXX
ifAlias.26 = STRING:
ifAlias.27 = STRING:
ifAlias.28 = STRING:
ifAlias.29 = STRING: XXXXXXXXXXXXXXXXXXXX
ifAlias.30 = STRING: To switch first floor
ifAlias.31 = STRING:
ifAlias.32 = STRING:
ifAlias.34 = STRING:
Interface description mapping to optical interface indexes mapping
snmpwalk -v 2c -Ofs -c <Communication String> <IP> 1.3.6.1.2.1.47.1.3.2.1.2
mib-2.47.1.3.2.1.2.67305550.1 = OID: ifIndex.5
mib-2.47.1.3.2.1.2.67305614.1 = OID: ifIndex.6
mib-2.47.1.3.2.1.2.67305678.1 = OID: ifIndex.7
mib-2.47.1.3.2.1.2.67305742.1 = OID: ifIndex.8
mib-2.47.1.3.2.1.2.67305806.1 = OID: ifIndex.9
mib-2.47.1.3.2.1.2.67305870.1 = OID: ifIndex.10
mib-2.47.1.3.2.1.2.67305934.1 = OID: ifIndex.11
mib-2.47.1.3.2.1.2.67305998.1 = OID: ifIndex.12
mib-2.47.1.3.2.1.2.67306062.1 = OID: ifIndex.13
mib-2.47.1.3.2.1.2.67306126.1 = OID: ifIndex.14
mib-2.47.1.3.2.1.2.67306190.1 = OID: ifIndex.15
mib-2.47.1.3.2.1.2.67306254.1 = OID: ifIndex.16
mib-2.47.1.3.2.1.2.67306318.1 = OID: ifIndex.17
mib-2.47.1.3.2.1.2.67306382.1 = OID: ifIndex.18
mib-2.47.1.3.2.1.2.67306446.1 = OID: ifIndex.19
mib-2.47.1.3.2.1.2.67306510.1 = OID: ifIndex.20
mib-2.47.1.3.2.1.2.67306574.1 = OID: ifIndex.21
mib-2.47.1.3.2.1.2.67306638.1 = OID: ifIndex.22
mib-2.47.1.3.2.1.2.67306702.1 = OID: ifIndex.23
mib-2.47.1.3.2.1.2.67306766.1 = OID: ifIndex.24
mib-2.47.1.3.2.1.2.67306830.1 = OID: ifIndex.25
mib-2.47.1.3.2.1.2.67306894.1 = OID: ifIndex.26
mib-2.47.1.3.2.1.2.67306958.1 = OID: ifIndex.27
mib-2.47.1.3.2.1.2.67307022.1 = OID: ifIndex.28
mib-2.47.1.3.2.1.2.67321934.1 = OID: ifIndex.29
mib-2.47.1.3.2.1.2.67321998.1 = OID: ifIndex.30
mib-2.47.1.3.2.1.2.67322062.1 = OID: ifIndex.31
mib-2.47.1.3.2.1.2.67322126.1 = OID: ifIndex.32
