How to check ping to two external IP
  • Kirin2
    • Jul 2018
    • 28
    I'd like to monitor if Internet connection in my office is fine. So, as I understand, I can ping external IP( for example, google.com) and if it don't respond several times, trigger will be ON. But I don't know how to realize this in Zabbix. Also we have 2-nd(reserve) Internet provider, and I'd like to check if connection is good on the 2nd too.
    Mb somebody know how to do this?
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi kirin ,
    You have many options to monitor internet connections:
    1 - with ping (ping ip01 and ip02 after create trigger to validate result is up to one or two ips)
    2 - with scripts, speedtest-cli in python, its good with pre-processing , after create triggers.
    3 - with network traffic your device or router by snmp
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Kirin2
      Kirin2 commented
      Hi, Hernandes, thank you for your response
      I solve it by defining traffic law to 8.8.8.8 by one gateway and to 8.8.4.4 by another, then I've created 2 new hosts with ICMP Ping to 8.8.8.8 and 8.8.4.4
  • mansourh12120
    • Jun 2021
    • 10
    hello everyone!
    i want to monitor traffic between tow ip address in zabbix , how can i do it?
    • Poiny22
      • Sep 2023
      Up!
      can you please share how did you do it?
      I have 2 Internet
      one is tie to ISP1 line and the other tie to ISP2
      ping to destination of
      8.8.8.8, 8.8.4.4
      In this I will know the difference latency of each ISP.
      Please help me how to do it. Thanks.
      • dominicw
        • Oct 2023
        Just monitor the default gateway on both ISP's?
