Data type: decimal not found in zabbix 3.4 | away
  • washington
    • May 2017
    • 13
    Hi Zabbix 3.2 i can see the form Data Type and choose options: Decimal, Octal, Hexadecimal and boolean.
    But in Zabbix 3.4 i can't see that form more, i see a link name "Preprocessing", and when go to there, I find somethings like:
    • Text
      • Regular expression
      • Trim
      • Left trim
      • Right trim
    • Arithmetic
      • Custom multiplier
    • Strutured data
      • XML XPath
      • JSON Path
    • Numeric
      • Delta
      • Delta per second
      • Hexadecimal to decimal
      • Octal to decimal
      • Boolean to decimal
    • Change
      • Simple change
      • Change per second
    • Numeral Systems
      • Boolean to decimar
      • Octal to decimal
    between this options above, what is the "data type: decimal" like in old version 3.2?
    Thank you very much
    Washington Anacleto da Cruz
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi man
    Look in item
    Type of information = Numeric (unsigned)
    Regards
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
